Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9190 Views
  • 127 replies
  • 18 likes
Archicad 26 Update 4004 Preview - Antialising BUG
I created a comparison video between 25 and 26 where you can see the problem between the two versions.This cannot be considered a bug because it is not something that is triggered with a certain action.It affects the total workflow of the software an...
Botonis by Advocate
  • 2798 Views
  • 21 replies
  • 1 likes
Resolved! Building pad
Hello, Is there a quick and easy way to create building pad without having to transform the original topo (creating a copy, layer etc...) (similar to revit building pad fonction). Thanks a lot!
DWG Translators and Teamwork, best practice
Hi everyone. When setting up BIMcloud (basic in our case) and templates what is considered best practice for the location of the DWG translators? Should they be placed on BIMcloud or a shared network drive, or is it easier to have every user copy the...
Nik by Booster
  • 114 Views
  • 0 replies
  • 0 likes
Resolved! Surface Heat Transfer
Hi! Can someone explain this parameter to me? I am not sure how to determine these coefficients and what they are used for in the Energy Evaluation tool. Aren't the specific U-values for the materials used when running an energy simulation? I have re...
Shell Tool
Has anyone experienced a crash when opening the shell tool in AC 26 on a Mac?
Bullish by Participant
  • 117 Views
  • 0 replies
  • 0 likes
Element Hide
How to hide/unhide the any elements ? we are find a layer off option but it's not working instead of hide
Angled cuts on lumber
Iʻve got two 2x4ʻs that I want to join together at a 45*angle. They are both on their two inch side.In my selection settings, it is not giving me the option to make a horizontal cut or give me the option for segment angle in that section. Any ideas w...
Paa by Booster
  • 346 Views
  • 5 replies
  • 0 likes
