Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 7527 Views
  • 126 replies
  • 16 likes
Creating an excavation plan
I need to try my first attempt at an excavation plan in ArchiCAD. I have an existing topo survey with contour lines and a completed civil plan with finish elevations. I need to create an excavation plan to figure out how much dirt we need to excavate...
Anonymous by Not applicable
  • 2993 Views
  • 5 replies
  • 0 likes
Inclined Beams with rectengular endings?!
hi all, any chance to get inclined beams with rectengular endings. I am struggeling hard to build a steel structure with the included steel profiles as objects. thanks for hint!
  • 4575 Views
  • 12 replies
  • 0 likes
Door & Windows not appearing in plan view
Hello all, None of my windows or doors are showing in plan. MVO options are set to "show on plans", I've also gone to door/window settings>opening lines to override MVO options but still no luck. Anybody know what I might be missing?
  • 3753 Views
  • 3 replies
  • 0 likes
Defining materials in a macro?
Hi everyone, is it possible to gather general material definitions to a macro object and call them to object files by using PUT and GET commands? I've tried this method but have gotten many different error messages such as "incompatible table paramet...
  • 1103 Views
  • 3 replies
  • 0 likes
Thermal bridge problem - missing materials
The thermal bridge calculation is failing to complete on some details and the error message tells me that it's because a 'Material does not exist' All the fills in the drawing have a material assigned, with all the properties in place. Some of the de...
  • 3896 Views
  • 3 replies
  • 0 likes
Complex rounded stairs
I have a problem with creating stairs with shape as in the image I attached. It's kind of curvy, elliptical shape and it's very hard to make it I've tried to make them using Create stairs using selection but I keep getting this "line of travel endpoi...
Swimming pool on Archicad
Hi, im quite new to archicad. currently working on a design and i need to add 2 swimming pools, of 25 by 13m and 7 by 13m , but whenever i try getting the components off archicad, i am unable to adjust the dimensions . I also tried the 'resize' comma...
  • 2705 Views
  • 2 replies
  • 0 likes
Archicad Trees
Hi All, I need some advice on the best way to place trees in Archicad. I have usually been using the 3D "Tree Model Detailed 18" as I like the tree to look realistic when I'm exploring the model in 3D. I really hate how the billboard trees only face ...
  • 6663 Views
  • 3 replies
  • 0 likes
error with custom dot-pattern/halftone fill
Hi, I'm working on a set of presentation drawings and would like to use a simple dot-pattern or halftone fill on the elevations. I'm not a fan of the percentage fills because they're too solid and don't fit the graphic style in this particular projec...
  • 1259 Views
  • 1 replies
  • 0 likes
Guide lines
I've never cared for the guide lines tool but I thought I'd try it in 19 it won't do anything for me no guide lines anywhere. I've clicked on the guide lines icon it darkens but no results. I went to the youtube videos but its leaving me clue less. I...
  • 1168 Views
  • 2 replies
  • 0 likes
