Wall Edges - Not looking surface-wise, like rests of wall?
Can't figure this one out? What's causing these "edges of walls" to behave in this manner? Why the "white" areas?
I don't know if I've been away from gdl far too long but I can't seem to figure this out. The script below is Archicad generated from an object I created and saved as a window. It's a piece of house log, 12" long, D shaped with tongue and groove. I'd...
Any way to change the shape of an existing stair but using the same raill, tread, material parameters? Say from a straight run to an L shape but all other parameters stay the same? Never have been able to figure out how to do that.
Hello, I've been experimenting with creating a custom window according to the following instruction: http://helpcenter.graphisoft.com/tips/how-to-create-custom-window/ So I made some window shapes with the slab tool. But when I place the window in th...
Just curious...read one of the threads and it said that only in the UK and to subscribers was the "Modular Joinery" objects available? wondered if it was built into AC18 already?
Is there a way to extract the global coordinates of the local coordinate system in GDL. Sometimes (after numerous ROT and ADD's) it would be nice to know to coordinates og the local coordinate system.
see attached.
Hello everyone! I am relatively new to archicad environment and my question refers directly to the proper implementation of the Velux libraries. As you can see the problem I faced is that the skylight part of the window interacts with the roof and cr...
Surely the user has previously been able to DRAG multiple elements on multiple layers simultaneously… For some reason this command appears not to be working …. with bold marque on, layers unlocked, unlock checked. Even tried the 3D grouping trick, to...
well, ok, I have a corner sliding pocket door condition. I'm getting this "sliver" of a piece of material that occurs in the corner. The walls that meet the corner are made up of 4 walls. 2 walls (running top to bottom of the image) create the "shell...
User | Count |
23 | |
7 | |
6 | |
5 | |
5 |
