Design forum
Forum Posts
Plan View not displaying correctly with Complex Profile
I am trying to create a wall with a Stone skin and sill below the window and siding above the sill (when there is no window). I used a composite wall (1/2"gwb, 5 1/2" studs, 1/2" sheathing, 3/4" air space, 3/4" siding) as the full wall and then appli...
Anonymous by Not applicable
  • 9301 Views
  • 12 replies
  • 0 likes
Live Edge Pine Siding
Hello All, I have to side a house with a "live edge" pine siding. How would you go about it? Try to make a surface look correct. Or model it with angles walls. Or a complex profile? hmmmmm. Any advice would be great.
  • 2057 Views
  • 1 replies
  • 0 likes
AC17: Doors + Windows in Composite Structures Review
Based on the changes with PBCs and Building Materials introduced in AC17 I am re-evaluating my workflows for construction documents and would like to review what solutions, opinions, workarounds or bugs are the result of these improvements. In Puerto...
Autoselect when undo-redo disabled in ArhiCAD 16
Hello, I use the trick with undo-redo to select things i've drawn the last few steps. Like drawing 5 lines then undo 5 times then redo 5 times and you select all in less than 1 sec. In AC16 that autoselect feature is disabled. How can I reactivate it...
  • 1007 Views
  • 0 replies
  • 0 likes
soccer stadium 15000 seater
Hey people am a newbie here and i got this project am doing for a stadium of 15000 seater i need help on how to link the column and the tiers and also how do i set up the staircase to merge with my slabs?
  • 1151 Views
  • 1 replies
  • 0 likes
How to view 2D pdf/jpeg/png in 3D perspective/axonometry!?
I wanna do something like this http://bimes-bim.blogspot.ro/2012/09/how-to-view-2d-lines-in-3d.html but with a file and it looks to be impossible! Thanks! Best regards! http://nemetschek-scia.com/sites/nemetschek-scia.com/files/styles/slideshow/publi...
  • 3900 Views
  • 3 replies
  • 0 likes
"Cutline JM10" not masking?
I am using the Cutline JM10 on my detail, but it doesn't hide one side of the cutline, so I have to draw white fills myself. The mask settings don't do a thing at all, is this a bug, or am I doing something wrong?
  • 3133 Views
  • 5 replies
  • 0 likes
display order with doors
Hello. I currently have two doors that intersect. I would like the display order to be different, namely the left one to be on top of the right one, so that the marker does not cover the left door. How can I do that? Thank you.
  • 1192 Views
  • 2 replies
  • 0 likes
Modular Wardrobe bug
Hello When I use a modular wardrobe, and in the "module plan" settings, the diferente dimensions I define, changes to the uniform dimensions after I close the settings and return to then
  • 2476 Views
  • 3 replies
  • 0 likes
Open Web Joist
I'm modeling my floor joist, but there isn't a wooden open web joist available in the ArchiCAD Library, and I'm not getting much luck finding it elsewhere. I created a truss myself that resembles an open web joist, and it works... but it's extremely ...
  • 1033 Views
  • 0 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
