Design forum
Forum Posts
Layers and Symbols
Hi there, I'm quite new to ArchiCAD, and am crossing over from using Vectorworks, which I've used for about 20 years. So far, everything is going pretty smoothly, but there are obviously a few teething problems I'm having! I am wondering if it's poss...
Anonymous by Not applicable
  • 2522 Views
  • 5 replies
  • 0 likes
Custom Door Leaf/Panel not showing in Door Settings
Hi, working in v17 & a custom door panel which i made with the slab tool isn't showing up in the pop-up menu within the Custom Panel leaf type. I followed the instructions in the menu, & made sure that the library is loaded (no choice, seeing as i ca...
COLORBOND® steel Texture Library for ArchiCAD
We have updated our free COLORBOND® steel texture libraries for ArchiCAD. Package includes the latest COLORBOND® steel colours; Cove™, Mangrove™, Gully™, Wallaby™, Terrain™, and Basalt™. The installation instructions are included in the download. We ...
  • 1753 Views
  • 1 replies
  • 0 likes
Staircase Balustrade
I want a wooden balustrade on my staircase, but the only style available is extremely unpleasing, I went through all the parameters but couldn't find one that changes the style of the balustrade. Did I miss anything, or am I stuck with this ugly balu...
  • 3553 Views
  • 3 replies
  • 0 likes
Structural Plan
I have just started using this software and have run across a problem. The structural plan for my building will not go away and is giving me grief with the rest of the project. Any help?
  • 941 Views
  • 1 replies
  • 0 likes
how to do a bookshelf
hi ,I'm a new guy . I want to do some interior work with archicad. but I have no idea about The most simple thing..... for example , a bookshelf like this.
  • 4255 Views
  • 3 replies
  • 0 likes
Trouble with windows
Hello. Having trouble with putting windows into walls. Some walls dont let to put windows at all. Dont get it coz some walls have let me put some windows. Program has sayd "this window expands over the wall" I dragged one window to another story but ...
  • 2469 Views
  • 3 replies
  • 0 likes
Fill setting for solid walls in presentation plans
How do I get the wall fill settings to display a wall with a heavy outline (60mm) and a greyscale fill?. I am using the presentation-solid setting in model view and the override cut fill is the same pen as the wall's cut pen line. In my case is shows...
  • 9582 Views
  • 3 replies
  • 0 likes
MORPH TOOL
TWO THINGS. ANYWAY TO SET AMOUNT OF SEGMENTS IN A CURVED MORPH? 2ND ANYWAY TO USE TUBE TOOL AND PULL A MORPH ALONG A CURVED PATH? USING A MORPH FOR EXTERIOR TRIM, WORKS NICELY ON STRAIGHT LINES.
  • 1212 Views
  • 2 replies
  • 0 likes
No Copy Paste from Multiple Storeys
Here's a new one for me. Has anyone come up with the attached message when copying and pasting from plan to elevation? It just involves 2D lines, text and fill.
  • 6872 Views
  • 12 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
