Resolved! Elevation Sun and shadow settings
In some of my elevation settings when I check the "Sun and Shadow" box on, the sun/shadow settings do not appear underneath. Is there something else that hides those settings?
Hi,I have a problem with making an object.I imported an 3DS file into ArchiCAD, since i can not transform it into MORPH (because size of file gets too big), i made a gls direct from impotet object - its size is still 8 mb to 16 mb. I don't know how t...
We have been trying to model a stair with two straight runs and a curved portion, with a single sweeping balustrade. As shown on the attached screenshots, it's drawn with two straight reference lines and a semi-circle between. However we edit both th...
When i right click for the popup menu to search under "Move" for the "Drag Copy" command, it shows a key shortcut of "option-command-D" On a mac, when i press option-command-D, I don't get "Drag Copy" "Option-Command" gives me "Inject Parameters" & t...
Hello folks, I am trying to visualize elements of the floor below which should be visible. In my case, it is a first floor from which, in plan, I shouhld visualiza part of the garden at ground floor and part of the stairs (the other part should be hi...
(Link to Original post inserted by Moderator) https://community.graphisoft.com/t5/Design-forum/Launching-customer-user-groups-in-Q4-2021/m-p/225354/highlight/true#M121454 In case you missed this in the Archicad 25 thread...If you want to give feedbac...
I'm curious how everyone is authenticating Archicad 25 in an office environment. I understand that every installation needs to be authenticated but I don't see the sense in registering a GSID for each user (20) and I don't want to use my ID since eve...
You can read the press release on the following link: https://www.nemetschek.com/en/news-media/newsroom/Nemetschek-Group-Brands-Graphisoft-and-Data-Design-System-Joining-Forces-to-Further-Expand-Integrated-Multi-Disciplinary-Building-Design-Solutions...
Still having trouble with the Floor Plan Cut Plane to show the wall lines from storey below or above the current storey. I set wall to be projected overhead in wall setting and dashed line for the overhead line. And set 4' from below in the floor pla...
i am creating the eave of a porch the barge board from the gable end is touching the end of the fascia board that holds the gutter it is trying to miter the two beam elements as they touch i just want to see the vertical end cut of the barge board te...
User | Count |
23 | |
7 | |
6 | |
5 | |
5 |
