Design forum
Forum Posts
help required 2d symbol in gsm
I am trying to create the New vent Window in ArchiCAD using Gsm Script. I had created the all frames and louver blades in 3D Script. In 2D script at present i am using the 3D Projection concept. In this case I am getting all the 3D objects projection...
Anonymous by Not applicable
  • 1587 Views
  • 1 replies
  • 0 likes
Color of Door
I seem to have this great big green fill on my plan views. Opening the door setting, there doesn't seem to be any color representing that green in Floor Plan & Section settings?
  • 1613 Views
  • 3 replies
  • 0 likes
AC17 Thermal Bridge Simulation ??
We are excitedly exploring 17 and there are some great features. Looking at the integration of Ecodesigner Star (We did beta testing) I cant find Thermal Bridge Simulation. Does anyone know the situation with this tool which worked well in the ED* Be...
  • 10302 Views
  • 9 replies
  • 0 likes
AC17 Layout Auto-Update doesn't
I have just started using AC17. It seems as if drawings in layout, even if set to Auto-Update, require a manual update. Also, if the drawing is moved, the drawing number in the drawing title doesn't update either until manually updated. Did I miss a ...
Magic Wand and Mesh Not Working...
I have done meshes a thousand times on other versions. I'm using Archicad 16. I am having NO LUCK creating a contoured mesh. Even a test case does not work: 1. I create a rectangle mesh. 2. I draw simple curved splines ontop of the mesh extending bey...
  • 1855 Views
  • 1 replies
  • 0 likes
layer not unlocking
hi all, I'm trying to unlock a layer on a section. no matter what i do, unlock all layers, single layer etc, as soon as i pan/zoom select anything it reverts back to locked. I've never had this before and its a bit confusing. anyone have any ideas? t...
  • 1463 Views
  • 3 replies
  • 0 likes
Slab Nodes
When you add or subtract from a drawn slab, it adds additional node points, is there a way to delete these additional points?
  • 4744 Views
  • 5 replies
  • 0 likes
AC 17 Building Materials
I am just starting to create a template for the new AC 17 and am now attempting to wrap my head around the building material attribute. Does any one have a clever idea or best practice for organizing this new attribute? While it seems to fix a number...
Erich by Newcomer
  • 30245 Views
  • 38 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
