Design forum
Forum Posts
Component Level Design Workflows - Conversation & feedback
Hi All, Now in Archicad, most design and data are handled at the element level - assigning properties, using Graphic Overrides or setting renovation status are a few examples.To express design intent and extract data at a more detailed level, the com...
James B by Graphisoft
  • 9190 Views
  • 127 replies
  • 18 likes
Strange wall sticking out
I asked about this before, but no one replied . I am using two complex profile walls, and a profiled sill plate in between( it's nothing but a plate, except that I added an 'X' to it ), as well as a composite slab. I want a layer of stucco on the rim...
Anonymous by Not applicable
  • 2173 Views
  • 3 replies
  • 0 likes
Big files: why?
I assume it is common knowledge that the more layouts, elevations, sections you have in an ArchiCAD file, the bigger your file size. Even it seems if they are 'blank'. What is it about the ArchiCAD architecture that means that layouts/sections/elevat...
  • 3031 Views
  • 3 replies
  • 0 likes
window parameters - transparent background?
can someone please explain WHY the window parameters is NOT making the window be "transparent"...??? it's an overhead round window. its blocking my windows showing up in plan. I NEED to see the windows in the wall 'below' this window that is position...
rob2218 by Booster
  • 2501 Views
  • 4 replies
  • 0 likes
Bulding material connections
Hi, sometimes I have a certain problem with connections of building materials. Here for example a wall profile connects to two slabs. Concrete material is the strongest so I expect the concrete in slab to connect to the concrete in wall. However, the...
  • 2660 Views
  • 4 replies
  • 0 likes
Curtain Wall question
So this is probably a simple problem. I'm making a curtain wall which I would basically like to be floor to ceiling glass with no intermediate horizontals. When defining the scheme in the curtain wall settings it looks like this will be the case. But...
  • 1783 Views
  • 4 replies
  • 0 likes
spot elevations on 10' grid to contours?
Just wondering if anyone knows of a method to change spot elevations on a 10'-0" grid into contour lines using the mesh tool. I'm thinking that if the mesh tool can produce a curvilinear smooth surface from the input points I could slice horizontal s...
  • 2363 Views
  • 4 replies
  • 0 likes
Problem using DATETIME in IF statement
I'm trying to write a code that will PRINT a message if it's a certain time or day. I managed to REQUEST the time and day ... call it out using TEXT2, however I cannot use it in IF THEN ENDIF statement. The code doesn't come up with errors until I tr...
jakubc7 by Advocate
  • 1298 Views
  • 2 replies
  • 0 likes
