Design forum
Forum Posts
RENOVATION FILTER SETTINGS V16
In the classic manner of drawings for a renovation, existing walls are left as line work and the new construction is poched darker. In the Renovation Filter Settings, I can't seem to find a way to change the settings for the existing walls to show al...
Anonymous by Not applicable
  • 950 Views
  • 1 replies
  • 0 likes
Can SEO be renovation filter specific
Hi, I'm new to ArchiCAD. I have an existing model that I would like to start modifying to create the proposed drawings. The problem is when I trim a new section of roof to an existing it then takes that section out of the existing plans/sections/elev...
  • 2855 Views
  • 4 replies
  • 0 likes
ELEVATION MARKED DISTANCE AREA
Hi, With the marked distance area it seems to go dark when using coloured elevations as shown in pictures below. in a previous project it became lighter and now its becoming darker any suggestions I've gone through work environment i need to it to be...
  • 2679 Views
  • 3 replies
  • 0 likes
"Random City" GDL Object released
The newest GDL Object based on User Wishes has been released: It can be downloaded from https://bimcomponents.com/ INT version: https://bimcomponents.com/GSM/Details/16026 USA version: https://bimcomponents.com/GSM/Details/16027 GER version: https://...
Vectorial hatches on multi-plane roofs
Is anyone else having this trouble with the vectorial hatching on multi-plane roofs in version 17? Show incorrectly on some surfaces when using the Internal engine in 3D and on elevations. The OpenGL textures align fine. This is from the INT Windows ...
Label Adjustment
I'd like to draw a "UP" arrow for the stairs, but can't seem to find in the settings where to change the "UP" text to sit like my red example?
  • 5728 Views
  • 10 replies
  • 0 likes
Layers in layout?
Hello, Have placed my elevations on a layout and am trying to figure out if I can turn off my site walls layer and have the change show on the layout. I tried to see if just turning off my site wall layer in the plan view would transfer the change to...
  • 9262 Views
  • 5 replies
  • 0 likes
False Ceiling
Hello every1 , I've just started learning archicad-15. I am an Interior Designer student from India. Usually here they use autocad which I find lil boring Anyways I wanna make false ceiling in archicad 15 but cant find it on youtube as well. Can anyo...
  • 4363 Views
  • 9 replies
  • 0 likes
Didn't find the answer? Start a new discussion
Labels
