laz89 wrote: it still doesn't show as how you have it? is there anything else i would need to change?
Go to the Display Options> Plan View> Opening Doors and change to 90 (note that with swing doors the opening setting is in degrees, in bifold and sliding doors it is a percentage)
Thanks for the help. I have it displaying correctly now. My problem was that I had chosen the bifold window from the cadimage windows but had put 2 bifold windows instead of having one window and splitting that up into 4 window panes (if that makes sense )
