building materials
Hi all
was just wondering if there is a reason that when you assign a building material in GDL scripting to an object but it doesn’t show up in schedules when using the assigned building material as the criteria ? i can elaborate if need be.
2 REPLIES 2
runxel
Legend
Well, you need to check for a library parameter. They are not directly linked to the other tools' parameters, so you need to have an additional criteria in your schedule. (It hides under the little arrow...)
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Awesome, Thank you
Learn and get certified!
