Design forum
change wall height
kokorajko
hi. It seems that I can only move walls, I can't chenge their height. I only have these tools on pallette when I click on corner.  Anyone help?obraz_2021-10-16_211944.png
2 ACCEPTED SOLUTIONS
ok, I click alt+g and pull option appears.
Sorry - yes, as you've discovered, if the wall is grouped with other walls, you have to suspend groups to do a variety of things.
One of the forum moderators   •   AC 25 USA and earlier   •   MacOS 11.6.2, iMac Pro
You cannot change the height of a wall that is linked to another story.  You have to set the wall to unlinked and then you can dynamically adjust the height and will see additional items in the pet palette.
Didn't find the answer? Start a new discussion
Labels
