Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
complex profile on vertical surface
Paopao
How would you put a complex surface on a vertical wall? I have an arch and I need to put a band around it. I am using the complex profle but I cannot find a way to ach it vertically. I normally would put the linear profle and thn use the ach from the palette to fit it to the arch. It doesn't work on a verticl surface though. Do I ned to use the form?
the pic shows the arch, the red profile is the band I need to put round it. There is also the section.
Thanks for any input.
PP
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
runxel
Legend
Maybe use a profile with the beam tool?
The new beams in AC 23 can be bent vertically.
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
Paopao
Ys, it is what I have ended up doing.
