complex profile wall / wall opening surface
leven
Hi. Do you guys think it's possible to have the sides of the wall opening with the same surfaces as the main face of the wall? (In my case, pink in the upper area and grey in the bottom part). It is a complex profile wall. The side seems to take on the surface of the material in which the window sill is.
Levi
(Using AC23)
11 REPLIES 11
leven
Thanks for all the tips and workarounds.
Levi
(Using AC23)
Erwin Edel
I ussually put a column with the correct building material on the sides. The column will merge with the wall in floorplan and there's no need for SEO. You can use a beam for the top part if needed.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
