Design forum
composite walls
Aussie John
I want place a recess into a composite wall. As such I need the parameters of the external skin of a wall so I can rebuild that part of the wall where the window is.
The global variable "Wall_skins_params" is an array. How do I get the information contained in the array for use in my wall patch?
I presume the window automatically knows which composite wall it is placed in.
thanks
Cheers John
[/size]
2 REPLIES 2
David Larrew
I haven't yet played with the new "WALL_SKINS_PARAMS" global parameter. But from what I read, the global is made up of an array totalling 12 columns and 1-8 rows. The columns indicate the referenced parameter. The rows store the value of the skin parameter (up to 8 skins).
Arrays are distinguished in GDL by: PARAMETER NAME[row#][column#].
For example - the 1st row of the 5th column would be: PARAMETER NAME[1][5].
I Hope this helps.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
Aussie John
thanks David, that did help
Cheers John
[/size]
Didn't find the answer? Start a new discussion
