convert xml and gsm
I met a problem when I used the LP_xml converter.exe.
When I click on the LP_xml converter.exe.It had a black window.But the
window fast disappeared(Flash back)and had not any error prompts.I couldn't
used the .exe file to convert xml and gsm file.
I want to know if I use the error way to open the LP_xml converter.exe.
I use the archicad 18.
Help me please.Thanks!By the way,I'm sorry for my poor english
7 REPLIES 7
Gergely Feher
You can read about LP_XMLConverter here: gdl.graphisoft.com/tips-and-tricks/how-to-use-the-lp_xmlconverter-tool/
_________________
Gergely Fehér
Team Leader, Library Team
GRAPHISOFT SE
Thank you for your answer!
I had readed the web link,but I still have a problem.
When I used LP_xml converter.exe,I should open the cmd window frist,
then drag and drop the LP_xml converter.exe in the cmd window to
running.It‘s right?
Gergely Feher
Yes, you're right, as lpxmlconverter is a command line tool.
_________________
Gergely Fehér
GRAPHISOFT SE
Ok.I know.
The picture import archicad then save to the gsm file.
The artifacts such as a chair aslo save to the gsm file.
Running LP_xml converter,then drag and drop the above gsm files to the
window,and write the words: "pathOfLP_XMLConverterExecuteable" libpart2xml -img "imageFolderPath" "binaryFilePath" "xmlFilePath"to
convert xml files.
Then I could embed picture with notepad++.
At last,I drag and drop the xml files in the window,and write words:"pathOfLP_XMLConverterExecuteable" xml2libpart -img "imageFolderPath" "xmlFilePath" "binaryFilePath"to convert gsm
It's right?
I want to embed picture in the gsm file to decoration the custom user interface.
haidu_bogdan
Hi all,
For all windows users I'm working on a gsm to xml app.
Anyone who is interested can download from github:
https://github.com/haidubogdan/Gsm-To-Xml-C-.git
This will be a tool in progress done with C#.
I'm not a expert developer so I it's not a perfect application .
Gergely Feher
haidu_bogdan wrote:
Hi all,
It seems a bit useless for me, as LP_XMLConverter does the same functionality... Why do you need another tool for the same thing?
_________________
Gergely Fehér
GRAPHISOFT SE
