curtain wall and normal generic wall intersection priority
aryastark
curtain wall and wall are intersects, but i want curtain wall shows instead wall without changing wall height.
it show half fill.
tried to change BM priority, didn't work.
tried poke up with nominal thickness inside curtain wall option.
none worked.
SEO worked but it making program heavier and slower if there is another method might better.
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
runxel
Legend
If you don't want to use SEO then luckily in this case there is an even better solution:
Model a beam with a high priority BMat (I have a "cutting air" BMat for that) on a seperate layer with the same intersection group number as the wall.
(A seperate layer so you can make it invisible.)
Lucas Becker | AC 27 on Mac | Author of Runxel's Archicad Wiki | Editor at SelfGDL | Developer of the GDL plugin for Sublime Text |
«Furthermore, I consider that Carth... yearly releases must be destroyed»
1 REPLY 1
runxel
Legend
