curtain wall can't show on plan but 3d and elevartion is correct.
John Wei
hi Users of Archicad:
I just update the Archicad form 23 to 25.
I have a problem of Curtain Wall tool.
as my photo. MOV of Curtain wall setting is all open.
on 3d model and elevation view, is correct.
but as the Curtain wall on 2d plan  view, I can not see whole item, just the reference line.
but, as I put the edit button, the issue is I can see on whole things.??
is 25 have more detail setting upload ?
John Wei
I solve my own problem, just the view of these ..
thanks .
Hello John Wei,
Did you check your curtainwall implantation floor ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
John Wei
thanks .
