dragging and dropping DWG or PDFs into Plan view
MMontgomery
Hey all -
I used to be able to drag and drop a PDF or DWG into ArchiCAD's plan view in AC 22. This feature works in AC 21 and AC 23. Did I miss a patch note?
AC 6-27 - Intel i9-9900K - RTX3090 - Windows 11 - 64GB RAM
Hello MMontgomery,
I just tested on AC22 with a PDF and a DWG. It works ! Can you be more specific ?
Christophe - FRANCE
Archicad Designer and Teacher
Archicad 15 to 27 FRA FULL
OS 11.6 Big Sur - MacBook Pro 2017 - 16Go RAM
MMontgomery
Dragging a PDF or DWG from a windows folder to the ArchiCAD plan view. Expected result is that the file is placed into the plan view as a drawing object. This works in AC21 and AC23, just not in AC 22. I feel like it must be something simple I'm overlooking. All layers turned on, all renovation elements showing.
