2018-01-14 05:44 PM
2018-01-14 05:46 PM
2018-01-14 06:18 PM
2018-01-14 06:22 PM
2018-01-15 02:47 AM
2018-01-15 05:07 AM
DGSketcher wrote:To "trap" this you can use this code in the parameter script:
Unless trapped in the GDL parameter script, it is possible to use the background pens with values 0 and -1, (window background & transparent) as a foreground fill pen which causes the error you refer to in the window.
IF mypen < 1 THEN mypen = 1 PARAMETERS mypen = mypen
2018-01-15 11:27 AM
2018-01-15 04:23 PM
2018-01-15 07:07 PM
Dave wrote:This is a similar issue as the riser material.
I just got new message today in yet a different project .pln (attached here). Seems like this is happening more often than before and reflects a software flaw.....
