file open
how do I open multiple GDL objects? The file manager window that opens on "open object" does not let me select more than one file.. why? I dont have time to put all the objects I work with in 2D space, because I can open all of them there if they are selected.
Besides, in AC13 there are internal object, so with each object open I have to select "browse files" in the first window.. It really slows me down when I am editing 200 objects on finalizing a library..
thanks for advice
Peter
2 REPLIES 2
David Maudlin
Peter:
To open more than one object, place them in plan, select them, then use the Open Object... command, you will get a dialog box asking if you want to open the objects. I have a .pln file with all the objects in a library placed in plan, so selecting and opening a group of objects for editing is simple.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Hello,
In the Special menu there is a command
to place all the objects of all the active
libraries into the floor plan.
It is a very handy way to check the 2D / 3D behaviour
and errors at once too.
To activate the Special menu check this forum or
Archicad wiki.
Regards, Juha
