flag for values{2}
I would like to create a group for values{2} - values, but it doesn't work. Can anybody help me?
Example:
I have this:
values{2} "A1" 1, 'opt1', 2, 'opt2'
values{2} "A2" 1, 'opt1', 2, 'opt2'
values{2} "A3" 1, 'opt1', 2, 'opt2'
etc.
many parameter with the same values
I would like to control them together, like this
options="1, 'opt1', 2, 'opt2'
values{2} "A1" options
values{2} "A2" options
values{2} "A3" options
etc.
but this doesn't work
Any ideas?
4 REPLIES 4
I have not checked this but my first idea is that you should not mix parameter types in a VALUES command. 1 is a number, but 'opt1' is a text. Try this:
values{2} "A1" '1', 'opt1', '2', 'opt2'
or this:
values{2} "A1" 1, opt1, 2, opt2
In this second case, opt1 and opt2 should be number type parameters.
First, thanks for the reply,
It's not a mix. I would like a numerical parameter values {2} which have a numerical expression, and descriptions as well.
like here:
http://gdl.graphisoft.com/gdl-basics/parameter-logic/
but my problem is, that as I have many parameters, I have to script this about 10-20 times, and If I have to change the values, I would like that all the 10-20 parameters would change together.
An other question:
Can I refer somehow to the parameters, as a number?
I have parameters like this
A1, A2, A3, etc
and I am looking for a way to loop the value description, like this
for i=1 to number_of_A's
    values{2} "A+number_of_A's"  1, 'opt1', 2, 'opt2', 3, 'opt3', etc
next i
Bruce
Arrays are your friend in this instance. You would declare two arrays - one for numerical, one for alpha (can't mix type when used in certain situations). Then you just use the array in your value statement.
E.g. DIM vDesc[],
VNum[]
Bruce Walker
www.brucepwalker.com
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC26 5002 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Thanks, arrays are the best
