1)
IS the AC13 file on the same machine as the AC11 file?
AC uses the OS fonts. Country Blueprint is not a standard
font, therefor you or someone manually loaded it.
Reload the font to the correct system folder. Process is unique to
the OS.
2)
Of course, you should change the text font to something like Arial,
just to make sure there is no other mickey mouse going on.
3)
You can and should run a search for your question before posting.
Do this now, you will find posts with the same or similar question.
4)
Please provide your AC version and OS in the signature line of your profile page. See my signature line below . . .
Snap
