go to last layou F7
David Bearss
Used to be when I pressed shortcut key I would be wisked away to the last layout I was working with. Now it defaults to the first layout of the publish set. Is there a way to customize this to the last layout?
David Bearss
Archicad 18/Windows 11
Alienware 17 R5
i7 2.4 GHz / 16 GB ram
1 REPLY 1
In my ARCHICAD the shortcuts are the following:
1.  Go to First Layout	   Ctrl + Shift + Left	 Goes to the first Layout.
2.  Go to Previous Layout	Ctrl + F7	           Goes to the previous Layout.
                            Alt + Left
3.  Go to Next Layout	    Shift + F7	          Goes to the next Layout.
                            Alt + Right
4.  Go to Last Layout	    Ctrl + Shift + Right	Goes to the last Layout.
It says F7 activates the Last Layout.
Of course you can reassign any of them in the Work Environment Dialog.
