Licensing
About all sorts of licenses, their management, Graphisoft ID, Graphisoft Store, License Manager Tool, etc.
help, Publish module file problem. I get *.mde file not *.mod file!!!
William Yan
hey guys, help,I set to publish module file, but the problem is I get *.mde file not *.mod file!!! Did someone know how to do with it?
AC 26 5002 CHI, Windows 10
4 REPLIES 4
I am guessing you are using the educational version of the software?
William Yan
yes, exactly, I am using the educational version. Is this the reason? Oh my. Thanks!
runxel
Legend
I think the solution in another thread was to rename it. You then can hotlink the module as normal.
William Yan
Cool operation!
