Design forum
how to connect small lines gaps?
aryastark
hi,
is there any method to extend and connect all small (let's say smaller than 10cm) line gaps, lines' tip should extend or add line patch extention towards to another line and close the gap?
(i don't want to adjust one by one, it is about whole lines to close small gaps in order to appropriate fill with magic wand tool)
Ver: AC23
Operating System: Windows 10 64-bit
Processor: Intel(R) Core(TM) i7-6700HQ CPU @ 2.60GHz (8 CPUs), ~2.6GHz
Memory: 16384MB RAM
Card name: Intel(R) HD Graphics 530
Chip type: GeForce GTX 960M
7 REPLIES 7
You're looking for the Adjust command, under Edit > Reshape > Adjust, also under the toolbar named "standard", or the shortcut ctrl- (ctrl minus) or Mac cmd-
You select ALL of the lines that you want to adjust/connect first (drag arrow selection box, or ctrl-click etc), then issue the adjust command ctrl- and finally click on an existing EDGE (mercedes cursor)...or draw a virtual line to adjust the elements to.
https://helpcenter.graphisoft.com/user-guide/136858/
One of the forum moderators   •   AC 25 USA and earlier   •   MacOS 11.6.2, iMac Pro
They will adjust to the longest length so if some of them are longer than others you may have undesirable results so make sure the ones you're adjusting aren't half as short as the longest ones you're trying to achieve
FREE wall Accessory framing and coverings
bit.ly/BIMRithmWallAccessories
FREE Truss object.
https://bit.ly/BIMRithmTrussV1
AC 24, Twinmotion current, Windows 11, Msi 10UG with rtx 3070, wacom intuos pro m, Wacom Cintiq Pro 16, razer Tartarus pro.
I am not so sure the shortcut for Adjust is working in 25.  Moving the mouse over the icon generates the a default pop-up in Windows   Adjust ( Ctrl+- )   It activates the Explode function for me.   ??
ArchiCAD 25 4013 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
Steve Jepson
https://www.youtube.com/watch?v=HvJ1CY1OIzU
https://www.youtube.com/watch?v=XYqQr_izH-k
@Steve Jepson Great videos, Steve!
some things are so easy to do, but so hard to put in words 🙂     Snagit = The Best Screen Capture Software (Free Trial) | TechSmith
And if you are wanting to join line end to end, just select and use the 'intersect' tool.
Versions 6.5 to 25
Dell Precision 3510 - i7 6820HQ @ 2.70GHz, 16GB RAM, AMD FirePro W5130M, Windows 10
Didn't find the answer? Start a new discussion
Labels
