Design forum
how to create different sash widths usign basic window
Lennox
Hi. Its a long time since ive been on this forum ! but wanted to start using Archicad more often and use
it for construction documentation as well as the design phase.
Im using AC 19 solo . Im using the double sash window in the basic windows library, however Im struggling to get one sash bigger than the other ( there is no editable  GDL hot spot).
Anyone help?
DGSketcher
Champion
@Lennox I assume things haven't changed too much since AC19 and the following is relevant to the Solo version. Go to Basic Window Settings > Shape > Panes Horizontal and choose asymmetric.
Apple iMac macOS Monterey / AC26UKI (most recent builds)
many thanks DG Sketcher , couldnt see it for looking at it!!
Didn't find the answer? Start a new discussion
