You can use Find & Select but there should be no need as the missing object should appear as a large dot the same colour as you pen number 1.
However to see the dot (or use F & S) you need to turn all layers on.
Then look at each of the storeys in turn.
If not there then look at each sect, elevation, detail, worksheet.
And if it is still not there then have a look on each layout page in case an object has been placed directly on a layout.
A schedule could be created to find a missing object but that only works if it is in a plan view - no good for sections, elevations, etc., because schedules don't look there.
