how to remove Missing Objects from the Library Loading Repor
Each time I start ArchiCAD the Library Loading Report shows me that there is a Missing Object from Attributes.
In this case the Missing Object from Attributes is MDW176 copy (1).
I would like to be able to find the thing that is causing this report and fix it or remove it so I don't get this message each time I start ArchiCAD.
How can I find the thing that is causing this report and fix it or remove it so I don't get this message.
The main problem right now is the message.
Thank you
0 REPLIES 0
Learn and get certified!
