Design forum
how to rotate a morph beam along long axis
How can I rotate a morph beam along long axis? see attached.
I had tried setting plane but no idea how to control ...
Regards
Podolsky
Mentor
If this beam is made from morph - you can rotate it in any plane - there is no limitation on XY plane as another tools. Just use rotate command. If it not working how expected in 3D space - try to rotate it in section.
Podolsky
Mentor
OK Thanks Podolsky
Didn't find the answer? Start a new discussion
Labels
