SOLVED!
how to rotate a morph beam along long axis
Hello,
How can I rotate a morph beam along long axis? see attached.
I had tried setting plane but no idea how to control ...
Regards
1 ACCEPTED SOLUTION
Solution
Podolsky
Ace
If this beam is made from morph - you can rotate it in any plane - there is no limitation on XY plane as another tools. Just use rotate command. If it not working how expected in 3D space - try to rotate it in section.
2 REPLIES 2
Solution
Podolsky
Ace
OK Thanks Podolsky
Learn and get certified!
