Llian wrote:
Thanks Christophe.
How can I "transfer" original DWG translator from Mac to Window base AC 20?
ON the MAC, in the translator setup dialogue, when you select a translator, you will see the path where is is saved.
You should be able to then copy these XML files to the Windows machine.
I am not sure that just placing them in the correct folder (where the other translators are) will load them.
But to be sure, you just 'Browse' on the Windows machine (in the translator setup dialogue), and find the XML files to import them.
