Am trying to make a rectangle outlined in an interior trim profile. I can make the trim run horizontally without a problem (profile is a beam). However, I can't make the beam go 90 vertically however (only allowed to go to 89 degrees vertical). I can make the vertical legs as a column, but I can't get the mitered corners to work. Have tried SEO but nothing seems to work.
Thought about using the shell tool on a flat xy plane, then create a GSM to stand it up in Z axis, but can't get that to work either.
Any ideas on how to do this? I would look like the architrave element in AV library, but with a different trim profile.
Thanks. Tom
