Ferenc & Djordje,
Thanks for the ideas, ...............
I did a select all with column tool on and the count came up correct. No duplicates. The column wrap was set not to wrap amd then I tried set to wrap. I tried these things before I called for help.....................same results.
But I think Djordje, you're probably on to something with the "break" routine in the short walls. However given that seems more complex than using the slab tool I am inclined to take the path of least resistance.
Also the 3d report is set for detialed, but not really certian how that would factor in since the count came up correct. Wold this report only initiate after an error ( my only real experience with the reports) or should I try and access it another way?
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
