2022-07-04 05:56 PM
is possible to change the location of the autoamatic saving files?
i spent 20 minutes searching in the Archicad 25 menu and 15 minutes in the 2000 pages help pdf file....
is a nightmare...i found the comand but not the place where is this command so....i can not find this command
can someone help me please?
Solved! Go to Solution.
2022-07-04 07:05 PM - edited 2022-07-04 07:09 PM
Are you referring to the location of the Recovery file?
This can be found in Work Environment> Company standards Schemes> Data Safety & Integrity.
Under the Data Safety dropdown, it will display the location where this saves. (See Screenshot Below)
**Note that while it's not recommended to change this, if you decide to do so, make sure you redefine your work environment scheme to avoid this setting going back to the default when you open up Archicad in the future.
2022-07-06 06:08 PM
Thank you very much
Subject | Likes |
5 | |
4 | |
3 | |
3 | |
3 |
