log profiles
Does anyone know of a way to create your own log profile using Log Home Solution? I've used "Adjust walls" to create a D shaped log that is 3 1/2' wide and 7 5/16" high but AC9 can't show it properly. The angles on the inside of the log are too big. When the outside of the log (the round side) meets these angles the height of the log actually shrinks and leaves gaps between them. Any thoughts?
have you tried using SEO ?
Dwight
uh.... custom profile?
EDIT:
Duh. Archicad 10 only. Upgrade already.
Dwight Atkinson
