If you can't do this with standard objects (I would not be surprised if you can't - but I don't use the standard GS library), then you will need to look at 3rd party windows.
The problem with that is your signature shows version 19, so you may not be able to find 3rd party addons now for that version and usually these addons will cost $$.
You will probably be better of just creating a custom window yourself (unless you need many different windows).
https://helpcenter.graphisoft.com/user-guide/88767/#XREF_93670_Saving_Rectangular
