2018-08-01 03:26 PM
2020-11-05 07:25 AM
grahamcole wrote:You are welcome. Very nice. For the sake of interactive schedules I add a .001" this skin in my Composites for vapor barrier and such. This is not for the sake of the schedules but for the sake of proper labeling in my Wall Legends. I frequently use a Wall Legend with each wall of the project that has each material in the wall label and a Wall Tag. Wall tags allow for all walls to display as simple 2 line walls. The wall tag links it to the all legend. As some scales, this is makes a much easier to read set of plans. This works for me because I never dimension to anything except the core of the walls/face of stud... never to finish dimensions unless a clearance dim is needed.
Thanks very much Steve. I followed your instructions and it worked!
ArchiCAD 25 5005 USA - Windows 10 Pro 64x - Dell 7720 64 GB 2400MHz ECC - Xeon E3 1535M v6 4.20GHz - (2) 1TB M.2 PCIe Class 50 SSD's - 17.3" UHD IPS (3840x2160) - Nvidia Quadro P5000 16GB GDDR5 - Maxwell Studio/Render 5.2.1.49- Multilight 2 - Adobe Acrobat Pro
2020-11-13 04:03 AM
2020-11-13 12:34 PM
