object saving problem in embedded library
ashwanikumarshukla
I am unable to save cabinet door as an object. after save error message is coming. Please see attached image. and i can't find that object in library. please help for solution.
Will anyone help me creation of kitchen cabinet as an object? Suggestion will be appreciated.
Ashwani Kumar Shukla
Archicad 12-26, 64gb ram, window 10
14 REPLIES 14
Erwin Edel
That is not an error message, just an information prompt telling you the object was saved in embedded library.
These are custom panels you can use for some of the kitchen library parts. You will have to choose custom panel and you should see a list of the ones you've saved to embedded library there.
If you've modelled the entire kitchen part as object, you should just save it as an object, not a kitchen cabinet door.
www.leloup.nl
ArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
ashwanikumarshukla
No, before save as an object for cabinet, i am trying to put cabinet door in plan. But can't succeed. Would you help me in creation of cabinet door? Bcoz after saving as cabinet door, i can't found the in Embedded library. That folder is showing blank.
Erwin Edel
This is where they show up. They are not objects you place in floor plan.
Excuse the Dutch, but I do not have INT library to show English, still the pictures used by UI should be the same.
www.leloup.nl
Windows 10 Pro
Roopa A
I created object using morph and object which is downloaded from archibase. And I am trying to save the file,
it is saving. But when I open it in other file its not coming. only 2D symbol is there.
In is showing as Invalid 3D symbol, Open the library part for editing and check its 3D script for errors.
I checked in this also.. I'm not getting were is the problem.
What is the issue??
Thank you,
Roopa A
Roopa A S
Lingwisyer
Guru
Not sure how that workflow works, but might it be saving the ArchiBase object as a Call within your end object? If that is the case, you will also need to load that object into your other project.
Ling.
Roopa A
Its working.
Last time I tried saving it from 3d view as top view. and when I open it in other AC file., it showed Invalid 3D symbol, Open the library part for editing and check its 3D script for errors.
Now I saved it from 3d as side view, its working fine.
Roopa A S
Roopa A
The object which I saved as object(.gsm) file, it is opening in one file, but when I try to open that in other main file where I want this object, It;s not coming, it's showing as invalid 3D symbol, open the library part for editing and check its 3D script for errors.
Why it is showing this??
Last time I saved the same file and it opened fine. But when I done the changes and saved the same file, its not opening. Its showing the error.
Where I went wrong?
Please help me out in this..
Thank you,
Roopa A
Roopa A S
Are there any CALL commands where it is calling in another GDL file?
If so then you need to load all of these files in a library used by your new file (i.e. the embedded library or some other 'loaded' library).
Roopa A
This is model I want. Which is created using 3 objects.
I loaded that object in new file, still it is not showing 3d.
It is showing this error.
I have loaded the image.
Please help me.
Roopa A S
Learn and get certified!
