2014-10-27 05:54 AM
2014-11-19 11:10 AM
2014-11-19 02:28 PM
2014-11-20 08:19 AM
2014-11-20 10:11 PM
2014-11-21 04:07 AM
Hmooslechner wrote:Hi Hmooslechner.
Hi Mariosmic!
Thx for the flowers..
Some ideas to Your polyline:
2014-11-21 04:51 AM
2014-11-21 07:35 AM
Hmooslechner wrote:
They made a function-change possible by using the normal object-dialog. That is a little bit "stone-age" in my opinion...
My idea goes this way: (not really my idea - it has been done similar in the random city object)
Place a little pictogram near the polyline in the drawing-editor - with a hotspot-switch. This should be possible to be turnd off after the operations.
If the switch is in the normal edit-field - the edit of the cornerpoints is possible.
If the switch is in the field for "growing" - the same hotspot works for growing of the polygone-shape
If the switch is in the field for segment-growing - the middle-point grows just this one segment.
If the switch is in the field for Corner-rounding - the same klick on the hotspot rounds the corner
If the switch is in the field for rounding the segments - the middlepoint works to round it like Your functionality.
This could be very near the normal polygon-behaviour in Archicad like editing slabs or hatches with the pet-pal.
The next thing i am thinking of - is: to use just one simple parameter for one polygon - one array with three dimensions for x, y, z and maybe some Flags for function changes - but that is future-music.. So it would be much easier to work with it in GDL - to copy the functionality for more open polygons in one GDL
In my last objects where i made three open polygons-profiles following an open path - it had to copy Esteban ramos-code in the 2D-GDL, the Masterscript, the Parameter-script and the 3D-Script and had to change the name of every parameter for each different polygone x+y (+ Z). The possibility of making some mistakes is very high - and very time-consuming for each profile.
Just one parameter-Array for all of this should be much easier and easier to understand... to alter and to use with less mistakes!
2014-11-24 06:24 AM
2014-12-01 05:19 AM
Hmooslechner wrote:Thank-you Hmooslechner. I'm working on many other parameters. It's very hard. But it seems there are not obstacles in the languages. It needs only time.
Hi Mariosmic!
Your Railing-part is obviously the best railing-Object for Stairs i have seen so far!
I will spread Your Video - in our region - to raise Your chances for selling it - if You like! Now its all going the right direction! i hope You are very proud of this!
2015-01-08 04:50 AM
2015-01-08 05:44 AM
boatingcow wrote:The code is locked cause I use it as master to make commercial object you can find on my web site.
These are brilliant. I'm slowly getting to grips with GDL and I wonder if you have a version that works in ArchiCAD 17 to look at the code? Thanks!
2015-08-05 09:27 PM
2015-08-05 10:55 PM
Roland wrote:I moved all the objects to a new website:
Most of the download links are dead, I don't suppose anyone could re-host?
2015-08-09 08:32 PM
mariosmic wrote:Thanks for that - you guys have some very nice objects.Roland wrote:I moved all the objects to a new website:
Www.3dmediadesign.it
You can find here the free and commercial object.
2015-10-23 06:35 AM
2015-11-30 12:24 AM
2015-11-30 09:44 PM
WSBN=WALL_SKINS_BMAT_NAMES[1] !building material t = REQUEST{2} ("Building_Material_info", WSBN, "gs_bmat_surface", surface) !!GDL-manual german S378 r = REQUEST ("Name_of_material", surface, name)I tried the code above in the masterscript - which works for both 2D and 3D-scripts - but it makes different results.
2015-11-30 11:57 PM
Hmooslechner wrote:You might want to try posting your concern on the new GDL Center Forum.
Please - if You read this, "GDL-Boss" - Yes - You - write back here "in the open", come into the discussion - take part - please!
2015-12-01 01:19 AM
2015-12-01 07:08 AM
Barry wrote:Why don't close this gdl forum?
http://gdl.graphisoft.com/forums/
Graphisoft seem to take a more active role with regards to GDL there.
