open Profile follows open path in 3d
Hmooslechner
Archicad 18 open Profile follows open path in 3d:
its an Archicad 18 3D profile-polygon:
in a few days at Bimcomponents:
"DynPolySchrIstTubeQuerschnitt"
before there downloadable:
https://www.dropbox.com/s/1c3svw53ipdp1a4/FreiformPolygon.pln?dl=0
my Dropbox. Its an AC18EduAut - file
Youtube english:
https://www.youtube.com/watch?v=jWLnMUIT6yA
48 REPLIES 48
sinceV6
Great work!
Good job. Heimo, continue this way!
No words. Awesome!
Think Like a Spec Writer
AC4.55 through 27 / USA AC27-4060 USA
Rhino 8 Mac
MacOS 14.2.1
that is so awesome.
vistasp
Just wow! Thank you Heimo.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
| AC 9-27 INT | Win11 | Ryzen 5700 | 32 GB | RTX 3050 |
Hmooslechner
I updated the dropbox link with the possibility of the object to edit the Profile which follows the path direct in 3D.
Also i added a new part which makes the same with 3 editable profiles also editable direct in 3d and a new parameter -z-offset to move the profile in 3D-Z, so that the path is better adjustable. After editing the path - set this z-offset to 0.
I work on a change of the additional points around the path-corners which are currently generated aut of the with of the first profile. There shall be e fixed parameter instead.
Then - it would be possible to simple copy the part to make additional profiles following the same path.
Cool!
One of the forum moderators
AC 27 USA and earlier   •   macOS Ventura 13.6.6, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
Hmooslechner
https://www.youtube.com/watch?v=kbABoH9mHjM&feature=youtu.be
the new features of this part in "nearly" english -
Hmooslechner
i added up to 50 optional rectangular profiles to the 3 freeform-profiles to test the script-idea.
You can test a AC18EduAut-file:
https://www.dropbox.com/s/q17cpwkkl96kau5/FreiformPolygon-1.pln?dl=0
By the way - did You know this part?
https://www.youtube.com/watch?v=1B54ETuhsDg
They are selling it within the library which is implemented in a service-contract yearly to pay here in the germany-austrian-region.
