paper width?
Aussie John
Has anyone worked out how to extract the width of the layout sheet?
The title "linear Drawing title 10" uses "gs_title_width_paper" but that doesnt seem to call up the width directly.
Also the sheeting indexes us the paper size so the info is there somewhere but how to get it?
Any ideas?
thanks
Cheers John
[/size]
3 REPLIES 3
The layout, grid, and drawing data are in parameter arrays in the drawing title object. The layout is ACLayout_Rect. So:
layoutWidth = ACLayout_Rect[3] - ACLayout_Rect[1]
James Murray
Archicad 25 • Rill Architects • macOS • OnLand.info
Aussie John
Thanks James
Is there any documentation on this? I not sure how it is working
Cheers John
[/size]
Frank Beister
I don't know a documentation of the layout object class, but there is a doc of the basic library, where you can find some of the constant local parameters: Basic Lib 10. Especially see Appendix A - Fix named optional parameters.
