question about GDL library door
when i place a library object door , in a second floor plan , this doesnt show correctly in the 2d floor plan , dont show the door frame and the wall hole , could you tell me what this happen ? i have check the door box , but i couldnt find the solution
thanks
Just maybe there is two walls in the same place?
Another problem could be the distance from header to wall base - the display could be affected because the door is getting inserted below or above the floor plan cut plane. - Just try Making the "sill to wall base" to zero.
Regards
hi ill check both tips , and lets see what happen , but i think we are on the right answer,
thank you very much for help
