2008-03-0709:19 PM - last edited on 2023-05-2305:02 PM by Rubia Torres
when i place a library object door , in a second floor plan , this doesnt show correctly in the 2d floor plan , dont show the door frame and the wall hole , could you tell me what this happen ? i have check the door box , but i couldnt find the solution
Another problem could be the distance from header to wall base - the display could be affected because the door is getting inserted below or above the floor plan cut plane. - Just try Making the "sill to wall base" to zero.
