"CALL"-bug Bug in 17.0.0 built 5005?
Frank Beister
I have a problem with modyfied objects:
Since the last hotfix I have problems with objects calling macro objects by name without extension in the calling text string. If I add the ".GSM" the call does work.
Can anyone confirm this or has similar problems?
1 REPLY 1
Judit Boros
Graphisoft Alumni
Graphisoft Alumni
Try loading the AC16 migration library together with AC17 library, should work without problem
Judit Boros
Technical Support Team
Budapest, Hungary
archicadwiki - the ArchiCAD knowledge base
