Design forum
"Place all loaded ibrary parts" Library part
Recently I had to reformat my hard disk and lost some miscellaneous bits and pieces I had collected over the last years. One was a library part that places all currently loaded library parts on the floor plan....and now I cannot remmember where I found it!
Ideas anyone?
5 REPLIES 5
Aussie John
from memory you can use the "Special Menu"
(opt-command) - for Mac, at archicad startup to access the hidden menu
Cheers John
[/size]
I know I've seen it before, but how do you access the special menu on a Windows platform?
hold down control & alt as you open it
Another way:
1)run REGEDIT.exe;
2)find the key named as HKEY_CURRENT_USER\Software\Graphisoft\ArchiCAD\ArchiCAD 8.1.0 INT R1\Special Menu, nad change the value to 1.
ArchiCAD 8.1.0 INT R1 may be not correct. it is according to which version of archicad u have installed.
Didn't find the answer? Start a new discussion
