I am having a problem with reading a text file
I am trying to use the TEXT extension and the DIALOG option but ArchiCAD refused to 'see' the text file and says its looking for a "GDL TEXT DATA FILE" and won't see the txt file.
Mac El Capitan and AC 19 latest build
It will see the file OK using the data extension but I need the TEXT option
as you can see the script is straight out of the GDL manual
Any ideas?
ch1 = OPEN ("text", "SHEET INDEX - AllLayouts", "SEPARATOR = '\n', MODE = RO, DIALOG")
nr = INPUT (ch1, 1, 1, v1, v2, v3) ! input of three values
! from the firstcolumn of the first row
PRINT nr, v1, v2, v3
CLOSE CH1
Archicad 4.1 to 27 Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
