Design forum
rendering improvements
Samuel EBULU-AMOUDA
With so many parameters, I wonder if there is a shortcut to get a good quality rendering.
6 REPLIES 6
Qualifa
Hello. As I believe, individual visualization parameters are applicable for each work and it will be best to choose for yourself.
So, the Archicad has built-in scenes for certain conditions.
Proud member of UNION.ARCHI Network
I was going to share two scenes so you could import them (one for exterior renders, one for interior renders), but I can't seem to find any way to attach files other than photos or videos in the way the forum is set up these days.
Maybe one of the moderators can clue me in.
www.leloup.nl
ArchiCAD 9-24 NED FULL
Windows 10 Pro
Adobe Design Premium CS5
It seems like the Forum no longer allows ZIP files to be attached.
I will raise this issue with Khoros.
Laszlo Nagy, Lead Moderator, Community Admin
Get Archicad Tips at https://twitter.com/laszlonagy
AMD Ryzen 1700X CPU, 48 GB RAM, NVidia GTX 1060 6GB, 500 GB NVMe SSD
2x28" (2560x1440), WIN10 PRO ENG, AC20-AC25
Loving Archicad since 1995
Or maybe the exportable file types like xml, aat, scene, mod?
www.leloup.nl
Windows 10 Pro
Based on the error message, XML already seems to be supported.
Bt all those AAT, Scene, MOD files could all be solved by ZIP format support as any of those files can be quickly zipped and then attached.
brucestar
In the photo render settings you can save a style that works for you - as described by Qualifa in another answer. If you put the render button (looks like a camera) on your toolbar you just have to click that for it to produce a render immediately. I put the render settings button next to it as well.
Didn't find the answer? Start a new discussion
Labels
