I have been working on the archicad file without hitting save for a day and the end of the day i closed the file without saving it.
I faulty double click the file to re-open to find out if there are any way to go back. I probably wiped the autosave because I did not open from Dock ICON.
My data safety & integrity setting :
checked:
ultra safe & make backup copy
autosave folder as use default location
undo limit:50 steps
I check the autosave folder under TW DATA BUT there are not pln file for the project file i was working on.
Does anyone knows how to retrieve the file? Thank you.
AFAIK the File is lost, autosave only works as long as you have done ONE previous save and the file crashes. If you had done at least one save you could have a BPN file which is a backup.
Eduardo Rolón AIA NCARB AC27 US/INT -> AC08
Macbook Pro M1 Max 64GB ram, OS X 10.XX latest another Moderator
One of the forum moderators. Versions 6.5 to 27 Dell XPS- i7-6700 @ 3.4Ghz, 16GB ram, GeForce GTX 960 (2GB), Windows 10 Lenovo Thinkpad - i7-1270P 2.20 GHz, 32GB RAM, Nvidia T550, Windows 11
