You don't say what version of Archicad you are using - also you operating system.
Best to add this to your signature in the Profile link at the top of the forum so it is in every post you make automatically.
I had no trouble with the same roof in 17 (latest hotfix).
Did you model it as one roof or did you connect roofs together.
If modelled as one roof did you model a rectangular roof and edit nodes to get the shape you want or did you model the entire clover shape straight up?
I did it both ways with no problems.
